Hey guys,
been a long time since I have posted anything! I have a couple questions, and cannot seem to find a definitive answer. Here we go...
I have a 1998 Dodge Ram 1500 Sport with a leveling kit and a 3" body kit running 35" tires. The truck looks great but drives like hell!! SMH! You feel all the bumps and the steering feels loose (constantly have to correct, to keep it straight) I just replaced the shocks and had it aligned and that helped a tad, but it seems to bounce quite a bit (at least it is not jarring anymore) and the steering seems loose. It is just nowhere near as smooth as it was pre lift.
The problems that I am aware of are..
-Needs upper and lower Ball Joints
-Need pitman arm replaced
Both of those problems could cause the ride quality to be poor, I know. My question is, I read about the angles are probably off on my tie rods and front end suspension. But I always thought the body lifts didn't hurt any of that (outside of shifter rod). Is there anything I should do or look for regarding the angles?
I figured since I was going to replace the pitman arm and ball joints I would go ahead and replace the tie rods, tie rod ends, idler arm, and control arm bushings (maybe sway bars too, just depends on the cost of everything). Any suggestions on what else should be replaced? What are your thoughts on replacing the whole control arm with pre installed ball joints? I read that the control arm bushing could cause poor drive quality and if I am going to replace them I might as well go ahead and replace the control arm? Should I replace both upper and lower? From a financial standpoint not sure I can afford both control arms, which would be better to replace with a new? Not sure which takes more abuse.
If I cannot afford to do all of this, what would you replace and in what order? Keep in mind the pitman arm and ball joints will be replaced no matter what.
BTW-Planning on going all MOOG, any other suggestions on brands?
Thanks in advance!!!
Tom
Tom
