All you have to do is unbolt both lower shock bolts and let shocks hang.
Unbolt sway bar links on each side.
Unbolt each upper shock and spring tower bolts.
Jack vehicle up and when high enough removed coil shock and stock spring ring .
Place spacer on and put all back in and bolt upper stuff first then slowly lower till lower shock bolt can be put back in.
Probably want to go with longer and better shocks while doing this.
Bolt the sway bar back too.
Lengthen axle breather hose, unbolt and remove each side brake line bracket for longer brake lines, extend CAD Vac lines.
