Did they add anything to the rear?
I was curious about how they set it up in the rear. Looking at RCX's website the 2.5" kit comes with front spacers and 2" rear lift blocks. OP probably has stacked blocks.
Oh I forgot to mention, that's a purty truck OP.
4 to 5 inches yes.......you will clear 35s easy.....I have them on my dodge and its a 5 inch lift and I clear them easy
5" is usually recommended for 35s, you're close enough. Good thing is OREs come with 4.10s which isn't that bad with 35s. You might wanna give your steering and suspension a look before them though. Things like track bars tend to be worn out.
