Small Lift on a Budget 1500 4x4
HighTechRedneck
318 Magnum
As the name states, I'm wanting to do a small lift on a budget. I'm not a big fan of spring spacers and blocks, so I'd prefer to stay away from those if I can. I heard somewhere that if I run Cummins 2500 4x4 springs all the way around I can net about a 2 inch lift? Or would I be better off to save up and run this (only if I can use my Rancho RS 5000 RS5198 shocks):
http://www.summitracing.com/parts/sja-d201k/overview/year/1995/make/dodge/model/ram-1500
The truck is in my signature and profile. Thanks for any help!
BBartow
New Port Richey, Florida
5.9L Magnum
You can only use the Cummins front coil springs. The leaves in the rear are 3" wide.
That skyjacker kit is fine.
HighTechRedneck
HighTechRedneck
318 Magnum
So if I slap on junkyard Cummins coils onto the front, and do a 2 inch add a leaf in the rear that would net out to 2 inches total lift? Will V10 springs work too, I know the regular 360 gas ones won't lift it?
And my 95 never had a rake from the factory (found it out reading some TSBs), so I want to keep it from being too tall in the front.
And stock shocks will still work?
Merc225hp
NA
truck
gas
Factory shock length will work up to 3" lift after that new ones are in order. Used springs please don't, you can get new ones cheap.
