Steering woes.....
1999LftdDODGE2500
Las Vegas, NV
Cummins 24 valve
So bear with me guys. I just bought a used 1999 2500 and the problems seem to have just begun. When the truck was dropped off it was great with nothing to be unexpected from such a big lift but it's been three days and now it's like I don't have any power steering when stopped or at low rpms and whenever I turn or apply the brakes I get this horrible vibration throughout the entire cab you can feel it through the brake and accelerator pedals but not as much through the actual steering wheel. It's almost like having manual steering when I go to pull in or out of a parking spot and it's really starting to get on my nerves. Any help is greatly appreciated and I do believe it has a reman ps pump on it. Thanks
Merc225hp
NA
truck
gas
How much lift is in this rig?
1999LftdDODGE2500
1999LftdDODGE2500
Las Vegas, NV
Cummins 24 valve
I believe it has a 6 inch body lift and a 4-6 inch suspension lift and sitting on 35's right now
Johnn123
Ontario
Post some pics up, and some measurements. Theres no way you have a 6" body lift. Most likely 5" suspension and 3" body.
1999LftdDODGE2500
1999LftdDODGE2500
Las Vegas, NV
Cummins 24 valve
I'm 5'10" and the top of my head is level with the mirror on the door
Johnn123
Ontario
Can you get some shots of the body mounts? And some of front coils in the top buckets?
