I have a 2002 Dodge Ram 4.7L, currently having issues with the lights staying on after I shut engine off, if re-start the turn signals and brake lights do not work. Each time have to disconnect battery for a minute then the are off. Turn signals and brake lights work again. Idiot lights come and go, ABS, Check Engine, Lamp out even though all are good. Speedo is erratic at times or doesn't work. Thought me headaches were over once I fixed the over heating issue. Any one else experience this. Checked a couple connections and looked clean and dry.
Thanks For Any Help On This.
