20's on 33's tire help
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Looking to go from 285/75/16 to 275/60/20 or 305/55/20 or 275/65/20 but am concerned I may run into rubbing issues while at full suspension articulation if I don't get the offset/backspace just right. I have a 01 4x4 with 2" spacer with new coils and shocks in the front and stock setup in the rear
Can anyone tell me what the biggest tire is that will not run with a 20" rims? I've searched around the sight but can't find too much info on a situation like mine. Thanks!
Gr8bawana
6.7 CTD
Sorry can't help you. I'm one of those old guys who has no use for those 18-20 inch wheels they put on vehicles these days. They serve no purpose other than looks since trucks are no longer made to be used as trucks.:Rant:
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I have 33's with 16's right now and it looks good but bigger rims would be nice, I think. I do use my truck, especially turning hunting season. But I can see where you're coming from
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
wheel width and bs/offset?
Rim would be 20x9 with 0mm offset for the 20"
But I am also now considering an 18" rim because I have been reading the 20s can be dangerous even with the mild offroad (logging roads) I do during hunting season. But I'm torn because i like the looka of 20s with aggreasive style tires... They would be 18x8 with 0mm offset.
BBartow
New Port Richey, Florida
5.9L Magnum
Yeah 8-9 wide 0 offset ~4.5bs is good
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Ok sounds good! I'm definitely not trying to push the tires way out, going for just about an inch outside the edge of the truck fenders because I am not trying to destroy my ball joints or steering with tires pushed out 3 or 4 "s lol
[email protected]
Magnum 5.9l
275x60x20
I have zero rub on my 2001 ram 1500 sport 4x4 360 gas, not sure about if its not a sport i also have a 1994 ram 1500 base 318, that ill be putting 4th gen stock wheels with 275x60x20 so ill let everyone know, I'm assuming at minimum I need a a level to get zero rub.
1Popeye
