HI
so I have a problem , I need to get my truck through provincial safety next month and i discovered while fixing a few patches that the rocker panels are shot . I have ordered a couple slip on replacement panels , and i have a flux core welder so I can stick them on . however there is a spot underneath that will be very hard / impossible to get the welding gun into . I was thinking I would use fiberglass to patch up the hole but the temps here are going to be below freezing and i am concerned that the fiberglass and body filler will not set up . I also want to use body-filler to smooth out and feather the repair to the panels .
any tips on how to do this in below freezing conditions would be appreciated . The temps should not be stupidly cold probably - 5C .
