clanceman427
I need to replace the door hinge bushings on my driver's door hinges on my 95 Ram 2500 SLT standard cab. I know I could find better hinges but I don't want to get into all the trouble of taking apart the ebrake and dash to get the hinge assemblies out.
I'd like to remove the door and rebuild the hinges "on the truck". I just did this on my 73 Chevelle SS and it went fine, however the spring location is different, and such that my spring compressor tool (looks like a skinny rectangular clamshell) doesn't fit within the space to get the Dodge spring off. I've already tried with the door removed, and fender still on, with the upper hinge in the "wide open" door position, and still can't fit the compressor tool.
Has anyone done this type of hinge rebuild "on the truck" and have any pointers, especially with getting the coil spring removed to facilitate the replacing of the pin and bushings?
