umbalaahh
- Dec 2, 2015
- 9
- 0
- 1994
- Magnum 5.2
Ok so here's the scoop, I have a 94 ram 1500.
The problem that just started today is that when running lights are on both the turn signal lamps and brake lights light up properly. However neither turn signal works when you move the switch inside and the brake lights are non responsive when applying brake. All other functions on turn signal lever work just fine, wipers/ hi beams. And all lights worked fine this morning when I left for work. Just curious if anyone has had this issue before and could maybe give me some direction to go in to avoid the dealer charging me a ridiculous diagnostic fee.
Also I forgot to add it has a fiberglass cap with a 3rd brake light which lights up when applying brakes which is making me even more confused as to why I have no brake lights. It's clearly getting power and bulbs are good so why don't the regular tail lamps work properly?
