Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Exterior
Exterior
Bring on the Bondo... (long)
This is a discussion on Bring on the Bondo... (long) within the Exterior forums, part of the 2nd Gen : 1994 - 2002 category!
Ok, so I have decided to try some body repair. May God have mercy on my soul; this is the ...
Like Tree6Likes
Sponsored By: BAK Factory Outlet
Reply
Old 09-07-2016, 08:03 PM   #1 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default Bring on the Bondo... (long)
Ok, so I have decided to try some body repair. May God have mercy on my soul; this is the point where I either save or destroy this truck.
Here is the rust on my truck. Between this truck and an '84 Mustang, my son and I are keeping pretty busy with projects but this is something I have never tried. I have watched a few videos and I think I have a pretty good grasp of the theory of it and I am reasonably smart (my wife might say different) but it's a little daunting. I wonder if I might get some opinions on each of the sections and what to look out for. The truck is a '98 and started life with those idiotic ground effects everyone loved back in the '90s. I ditched those earlier this summer but I think they did at least keep the rust at bay a bit longer than most trucks enjoy. After all of it is done I'll get under there with some undercoating and spray the hell out of it. Click for Ginormous images...
Thanks beforehand for any advice you can offer!
Passenger side rocker panel
Easily the worst area on the truck. Rust has eaten it's way through and is all along the rocker. The inside has heavy surface rust (see the picture of the hole) but is not rusted through. My plan is the sand it down then use a rust converter or remover on the inside. I thought of using a mesh patch on the big hole then just Bondo alone on the rest. After that, primer it up with some spray primer until I can afford to get it painted. BTW, the image is warped. The truck is not dented or anything.
Driver side rocker panel
Not as bad but I'm certain when I get it sanded down it will be worse. Sand it, remove rust, Bondo, primer, live happily ever after...
Passenger side bed behind wheel
Rinse, Lather, Repeat...
Driver side bed behind wheel
More of the same. Not rusted through...
Roll pan is chipped
Obviously not a Bondo area since it flexes but I was thinking of putting a patch on the back then laying down some fiberglass, sanding it down then priming it. The break is about 3" tall by 2" wide at the bottom. Unlike Bondo, I do have minimal experience with using fiberglass so I am fairly confident here.
There are other tiny areas where the trim trapped moisture and rust has started but if I can handle this I certainly can them.
Sponsored Ad
Register to remove this ad.
kdryan is offline   Reply With Quote
Old 09-07-2016, 09:54 PM   #2 (permalink)
Ram Year: 1999
Engine: 5.9
Default
If it were me I'd cut back to good metal and weld in patch panels but if you don't want to try welding they do have some good no-weld patch panel kits out nowadays. Eastwood sells one and I'm sure there's other places too
marine6212 likes this.
jsmith is offline   Reply With Quote
Old 09-07-2016, 10:14 PM   #3 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default
Do you have a link to that? I would be interested. I am not in a position for welding.
Old 09-07-2016, 10:41 PM   #4 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
I tend to lean toward the rivet-in style patch panels available these days. Bondo WILL crack and fall off within 1-2 years given how much you'll have to use.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 09-07-2016, 11:50 PM   #5 (permalink)
07MegaCabRam's Avatar
Ram Year: 2014
Engine: 6.7L CTD
Default
Man, Do I love living in Arizona. None of that crap around here!! Holy hell..
And do not use the word BONDO. That is the cheap stuff.. and body filler (bondo) shouldn't be around rust at all..
I worked at a body shop and trust me - this is no easy task, if you have not done this before.. Don't attempt it.
__________________
::2014 Ram 2500 CTD 4x4 Crew Cab
07MegaCabRam is offline   Reply With Quote
Old 09-07-2016, 11:52 PM   #6 (permalink)
Engine: 5.9 Magnum
Default
FWIW, we use EVERCOAT RAGE at work...seems to be alright lol
__________________
Old 09-07-2016, 11:52 PM   #7 (permalink)
Ram Year: 2014
Engine: 6.7L CTD
Default
Where do you live? Canada? Never wash your salt road gunt away?
__________________
Old 09-07-2016, 11:54 PM   #8 (permalink)
Engine: 5.9 Magnum
Default
Wut? You talking to me? I work in a collision shop. We don't fix rot or rust. lol
__________________
Old 09-08-2016, 12:51 AM   #9 (permalink)
Ram Year: 2014
Engine: 6.7L CTD
Default
No, sorry the Op.
Production collision is where it's at! That is where I was.
__________________
Old 09-08-2016, 05:42 AM   #10 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default
Well aren't we just superior... I've only had the truck a year and the only reasons I bought it were A: So I don't have to drive my 2013 Mustang in the snow and crap, and B: to have something my son and I could work together on. The object here is to learn, not to throw the thing away because we only want to swap out fenders.
I am not against replacing the rocker panels, in fact I would prefer it but I do not possess a welder, a place to weld, or even welding skills. My first thought was to have a body shop replace them but at $1200 per side it's a bit prohibitive and defeats the learning process. The stick on panels people are talking about here are tempting and using Bondo isn't my first choice; it's simply the most expedient method.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bondo correctly gurowar Exterior 7 03-13-2014 04:33 PM
Anyone ener tried 3M Bondo Restore Black Armyman14 Detailing 0 12-31-2012 05:51 PM
Bondo question the codes Garage 14 08-14-2012 11:24 PM
Bondo Anyone? dth418 Exterior 9 09-12-2011 03:12 PM
Bondo ramthis9501 Exterior 4 06-20-2011 03:25 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
