Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Exterior
Exterior
Bring on the Bondo... (long)
This is a discussion on Bring on the Bondo... (long) within the Exterior forums, part of the 2nd Gen : 1994 - 2002 category!
We use panel bond adhesive at work all the time. It's a two-part epoxy and works very well. BUT, surfaces ...
Like Tree6Likes
Sponsored By: BAK Factory Outlet
Reply
Old 09-11-2016, 11:53 PM   #21 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
We use panel bond adhesive at work all the time. It's a two-part epoxy and works very well. BUT, surfaces need to be real clean and your work time is a pretty short window.
I wouldn't see an issue with using panel bond if you have enough clean metal to work with.
One of my friends replaced most of his cab corners that rotted out and he use panel bond and so far it's holding up just fine, shit is like concrete lol
Sponsored Ad
Register to remove this ad.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 10-12-2016, 05:28 PM   #22 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default
Ok, so back to work on this...
I ordered this a couple weeks ago and when it came, needless to say it was a bit large and needed to be cut down...
I went around on the bonding agent and the gun for a bit debating wether to get the cheaper stuff and cheaper gun or just go with the 3m. I got this today in the mail. $80 on Ebay for gun and tube + 2 nozzles...
Cleaned up the rocker and the rust turned out to be a bit more extensive than I had anticipated... Paint was completely stripped by the time I was done.
Test fitting the cut down piece
Applied the bonding agent. After this I spread it out with a paintbrush as per instructions.
Went ahead and put a few pop rivets in as well since that area was going to be hidden. Note to self: DO NOT DROP THE PIECE IN THE GRASS WITH BONDING AGENT ON IT! Because I didn't do that... And I didn't have to clean it off with a cloth and do it all over again... No, not me...
Bottom with rivets in place. Should be enough to hold, I think.
3M says give it four hours to dry. I thought about using some body filler on the front seam but I think I won't. Next is to spray primer it then when I get all of the body work done I'll get it painted.
Let me say, I understand that this is a very amateurish job and I am certain that many body men out there that see this will be cringing. It is my first attempt of any kind at this and I know I am not any kind of an expert. I will keep this thread going for whatever body work I do from here on out.
Opinions?
jsmith and Joe w. like this.
kdryan is offline   Reply With Quote
Old 10-12-2016, 07:21 PM   #23 (permalink)
Ram Year: 1999
Engine: 318 5.2l
Default
Looks good man I wouldn't worry about what someone else thinks
kdryan likes this.
Joe w. is offline   Reply With Quote
Old 10-12-2016, 07:48 PM   #24 (permalink)
Ram Year: 1997
Engine: Magnum V8
Default
The reason pro's are pro's is because they do it all the time. A lot of us are amateurs and enjoy doing this stuff. Nice job man, looks good!
kdryan likes this.
clownprince is offline   Reply With Quote
Old 10-15-2016, 10:32 AM   #25 (permalink)
Engine: 5.9 Magnum
Default
Hey, it works. My only thing is always make sure ALL the rust has been removed and the whole area behind it shot with rust preventer.
clownprince likes this.
__________________
Old 10-16-2016, 07:07 PM   #26 (permalink)
Ram Year: 2015
Engine: Eco diesel
Default
Here is a site that can help you and your son do this body work it's called learn auto body and paint also has a site on you tube
15ecodiesel is offline   Reply With Quote
Old 10-16-2016, 07:13 PM   #27 (permalink)
kdryan's Avatar
Ram Year: 1998
Engine: 5.2
Default
No link...
Old 10-16-2016, 07:43 PM   #28 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Ya already did it. It looks good. My way is fill large holes with newspaper and then fill everything with fiberglass. Sand smoothish and finish with bondo. Sand that smoother and paint. Lasts a few years or sell it and shut up. Lol.
Tremclad rust paint thinned with varsol, use a air sprayer or electric and get a nice looking glossy paint job. Lasts a few years.
Rusty fenders get a nice Bushwhacker fender flare to cover them up. Truck looks like a million bucks.
Man, I like that panel cover though.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 11-06-2016, 11:39 PM   #29 (permalink)
Ram Year: 2015
Engine: Eco diesel
Default
Originally Posted by kdryan View Post
No link...
Learn auto body and paint.com
Old 11-07-2016, 05:10 AM   #30 (permalink)
Ram Year: 2016
Engine: hemi 5.7
Default
Well aren't we just superior... I've only had the truck a year and the only reasons I bought it were A: So I don't have to drive my 2013 Mustang in the snow and crap, and B: to have something my son and I could work together on. The object here is to learn, not to throw the thing away because we only want to swap out fenders.
I am not against replacing the rocker panels, in fact I would prefer it but I do not possess a welder, a place to weld, or even welding skills. My first thought was to have a body shop replace them but at $1200 per side it's a bit prohibitive and defeats the learning process. The stick on panels people are talking about here are tempting and using Bondo isn't my first choice; it's simply the most expedient method.
Is there a community college or technical school in your area that teaches welding?
When I took welding classes people used to drop of their projects all the time for us to weld up! You provide the materials and the get experience welding something different than a coupon!
marine6212 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bondo correctly gurowar Exterior 7 03-13-2014 04:33 PM
Anyone ener tried 3M Bondo Restore Black Armyman14 Detailing 0 12-31-2012 05:51 PM
Bondo question the codes Garage 14 08-14-2012 11:24 PM
Bondo Anyone? dth418 Exterior 9 09-12-2011 03:12 PM
Bondo ramthis9501 Exterior 4 06-20-2011 03:25 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
