Frame swap
Micchi
Micchi
West Lawn, PA
5.2L
Fingers are crossed that everything goes well during the inspection
Sent from my SM-G920P using Tapatalk
Micchi
Micchi
West Lawn, PA
5.2L
And the problem is back. Shop just called to let me know that it lost power. Had them pull the fuse and then disconnect the battery and the fuse but still nothing.
Micchi
Micchi
West Lawn, PA
5.2L
Pcm connection?
At this point I have no idea. When I got it to work yesterday I pulled that one fuse and it was good after that.
crazzywolfie
under the truck
try what i told you. to me it really sounds like a bad connection on the main power wire between the battery and power distribution center especially since stuff in the cab stops working also. i know i have dealt with more than my fair share of bad battery connections which is why when i buy batteries i switch to side post terminals. most aftermarket battery terminal clamps especially the painted ones like you have are junk. i would maybe even check the store to see the price on a new main power cable/clamp setup is. i know they are usually about $10 for a pretty long one but you might be able to get a 2ft one or something like that cheaper since i doubt you really need one that is super long.
Micchi
Micchi
West Lawn, PA
5.2L
What type of clamp would you suggest? Going to check it out after work tomorrow.
crazzywolfie
under the truck
either a crimp or solder on battery terminal would be the best route but might almost need a shop to do either. i really found the coated clamps like you have the absolute worst connection ever even tho they look nice. even just a plain non coated ones seemed to work more reliably than the coated ones but i find they have issues eventually. if you only have 1 wire from the battery to power distribution center than i would look just getting a new molded battery terminal/cable.
Micchi
Micchi
West Lawn, PA
5.2L
Well, got it to start and got the inspection done.
Gr8bawana
6.7 CTD
Did you find out what the problem was?
Micchi
Micchi
West Lawn, PA
5.2L
Maybe? Pulled the negative and then removed the fan fuse. Hooked up the battery started it and put the fuse in.
I hooked a toggle switch up to the run wire for the fans. I've been starting the truck before turning the fans on and I turn them off before I shut off the truck. So far no issues.
Well, there is 1 problem. Apparently the throttle valve lever and return spring vanished. Noticed it wasn't shifting right and was thinking the TV cable needed adjusted. Looked under the truck yesterday and saw the cable hanging and the lever missing.
Thought I tightened it when I hooked it up. Gotta make a trip to the pull it yard today since a new one from the dealer is $140 for some reason.
Micchi
Micchi
West Lawn, PA
5.2L
Much better now. Sounds good at wot and gets up to speed pretty quick.
Micchi
Micchi
West Lawn, PA
5.2L
Ugh, have codes p0300, p0302, p0304, and p0308. So it seems that one side of the engine is misfiring. Could definitely feel and hear it. Going to pull the plugs once it cools down
Micchi
Micchi
West Lawn, PA
5.2L
Well cylinder 2 has an issue the other plugs in that side looked clean. There is also a hairline crack on the insulator but that could have been from me removing it
crazykid1994
Florida
Check the injector. Hopefully it’s not stuck open. My o2 sensor shorted and all 8 plugs looked like that... the fact it was running right then started acting up might be something to think about. Have you done anything recently too any wiring or anything
Micchi
Micchi
West Lawn, PA
5.2L
Been driving it to work. Happened on my way into work last night. It was driving well and then it started acting up.
Micchi
Micchi
West Lawn, PA
5.2L
Pulled the valve cover off and turned the engine over by hand. The cylinder 2 exhaust valve doesn't move. The arm moves slightly but the valve doesn't open
