LMC projector headlights
lodell23
Has anyone used these? Are they any good? Thanks
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
if you post a link to the exact headlights, you might have a bit better luck with answers
dapepper9
Iowa/Nebraska Border
5.9L V8
I know which ones you're talking about. They are made by company called SpecDTuning. Complete junk and more expensive through LMC. If you want projector headlights I'd suggest going with the Spyder brand. Much better quality. I had the SpecDTuning housings before switching over to my LED bulb conversion and I'm much happier with my current setup
mitchbowers
Ohio
5.9 Magnum
Yeah, are you running stock housings with led's or? Cause I've been thinking about it myself
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
SpecD and Spyder are both garbage.
Anzo is only slightly less garbage. There is really no good aftermarket lights for these trucks that don't have serious fit/finish or quality control issues.
mitchbowers
Ohio
5.9 Magnum
Are those direct plug and play? Or is there a little bit of trimming to make the bulb fit?
mitchbowers
Ohio
5.9 Magnum
I always thought the aftermarket ones looked better until I got my stock replacements&know how much better they are output wise and how much better they fit lol
dapepper9
5.9L V8
I still wanna get some of those projectors and replacing the halogens they come with with LED bulbs as an experiment. I bet it would be pretty good. The halogens are H1s and essentially fog light bulbs but with brighter LED bulbs I bet it would be pretty good.
L
lodell23
Thanks for the responses guys. Anyone know a good place online where i can look at buying the anzo projectors?
L
lodell23
And how is the light output for an H7 bulb for low beams and 9005 for high beam?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I came across some anzo headlights on amazon searching for some other parts, they were like $170 though, at least they have a decent return policy.
