New lights
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
^What did you hit or what hit you? These trucks can normaly take a good hit and still stay together.
I t-boned a 4dr nissan car that pulled out in front of me when i was doing 70MPH, i didnt even have time to brake...
i had enough time to say "NO WAY YOU STUPID MOTHER FU BAM!"
he spun like 6 times and went rear first into an 8ft ditch, and honestly it felt like i hit a speed bump in the road, my truck Jarred and after i hit him i put on my blinker and pulled into the next parking lot like nothing happend, the wreck didnt even stop my truck, it only slowed me down to like 40mph, it was 80% cosmetic and the only thing broken was the a/c condenser, i drove the truck home with no problem, i pushed his pass 2 doors up against his center console, and his trunk LID was in the bed of my truck and part of his rear bumper was stuck in mine, it made a perfect cut, thats what that slit is about mid way up the bumper just to the pass side of the license plate... when my dad pulled up i had both feet on my bumper putting everything i could into pulling his steel bumper out of mine, i had honestly never seen anything like that before
txbass06
txbass06
NE Texas
5.9 Magnum
About 6 months later and I walk outside and see this on the passenger side
I just can't catch a break with this truck...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
how long is their warranty? If its out..........pop 'em out, put them next to a dehumidifier, or AC vent - let 'em dry out. Seal around he bulbs, run a bead of silicone (black GE Silicone II) around the outside - that outta do the trick!
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Mine do it too so you're not the only one.
JJ Damit. Stop beating me to posts. lol You can fix mine while we are at dave's
txbass06
txbass06
NE Texas
5.9 Magnum
I emailed them to see what kind, if any, warranty they offer. I checked all the emails and stuff I had for them but didn't notice any warranty info.
But my truck is like that... If I mention doing ANYTHING to it, something always happens.
I said something about re-doing the interior and my headliner starts sagging up front.
I was talking to a buddy about upgrading the audio, and my ancient headunit craps out.
Started gathering up stuff for my exhaust, and a baffle comes loose inside the FM I've got on there now.
Said something about getting JJ to do a set of retro's, and this happens
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Sounds like truck wants you to speed up the process on some mods
txbass06
txbass06
NE Texas
5.9 Magnum
I'm a guy that can't leave anything I own alone so I don't need a reason to lol
Warranty was for 3 months. Imagine that... But the company did say if I did re-seal them and had another problem, they'd sell me another set at their cost, which is better than nothing I guess.
I'll pull it out on my day off from work and see what I can't do with it
txbass06
txbass06
NE Texas
5.9 Magnum
Where should I look for that particular silicone?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
lowes, home depot, etc.
So, if you seal them back up and they still leak........they send you a set? thats weird.
txbass06
txbass06
NE Texas
5.9 Magnum
Thanks for the heads up.
The guy said that if I have another problem with them leaking after that, I could send my set to him, he'd look at them to make sure they're not physically damaged, and if they're not, I can buy another set from him for what he pays.
If I pull them out, re-seal them and they leak again, I'll just order a set of OEM's from work and send them to you lol
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
OEMs........if they have the fluted lenses would NOT be a good idea on a projector retro. Something to keep in mind!
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
If you want OEM I'll send ya my set. lol.
My lenses have an issue too Can't really see it in the pics but JJ you will see this month. They have like a ton of tiny cracks on the inside of the lens.
txbass06
txbass06
NE Texas
5.9 Magnum
Thanks for the heads up. Guess I'll do some more looking on them if I do end up needing another set. I'll see how the re-seal goes
