I had purchased some aftermarket wheels for my 98, after doing some research the wheels appeared that they would fit and after getting them in they didn't. The center caps are flush to the surface at the wheels. So they won't fit on the front due to the hub assembly and dust cover. The back are obviously fine since they are drum brakes. The front stick out around 1/2 - 3/4" so what I'm wanting to find out, does anyone know of some aftermarket hub assemblies that could work or possibly some modifications that don't require adding spacers so I can avoid the front protruding obnoxiously?
