Did some parts book digging this weekend. I found no diff for master cyld from drum to disc, but remembered a bud that did this swap and he had to change his proportioning valve.
Rear Disc brake part numbers for the Dana 60, 70, 80
52009919AA x2 @ $180 each, This includes the backing plate, parking brake shoes and all the hardware.
Fits
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M60 HD/248MM"+"Axle Ratio - 3.55"+"GVW Rating - "RHD Asia Region Group"0#"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete assembly. . "Axle - Rear, Dana M60 HD/248MM"+"Axle Ratio - 4.10"+"GVW Rating - "RHD Asia Region Group"0#"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 4.10"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 4.10"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 3.55"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 3.55"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M70/267MM"+"Axle Ratio - 4.10"-"Axle - Anti-Spin Differential". Required: 002
05018580AA x2 $94 each ADAPTER, Disc Brake Caliper
06504691 x4 Bolt Adapter to Backing Plate,Mounting
05017651AA x8 Bolt, Hub and Rotor
52009932AA ; 05017658AA $126 ROTOR. Brake" DANA M60 HD / 248MM RBI"+"AXLE RATIO - 3.55"+"GVW/PAYLOAD RATING"-A ANTI-SPIN DIFFERENTIAL". Required: 002
Calipers, take note these include the brackets, dodge part #05018580AA
RAYBESTOS Part # FRC11312 $153 Rear Left Professional Grade Professional Grade Friction-Ready Caliper, Remanufactured, Contains Bracket
RAYBESTOS Part # FRC11311 $153 Rear Right Professional Grade Professional Grade Friction-Ready Caliper, Remanufactured, Contains Bracket
Rear disc Pads
RAYBESTOS Part # PGD702AM
Rear brake lines
52009991AA Left
52009990AA Right
06035832 x2 Bango bolt
05015429AA VALVE, Proportioning
