Lethalweapon100
So i just replaced a U joint but the squeak remains. Can a wheel bearing still be bad and make noise even if it spins fine and is tight as new?
Yes, somewhat. Its less likely to do it if the wheel is turned either way. It really starts around 30MPH and then the sound will become much higher pitched around 55MPH and will not go away.Does it change with any steering input? Or road speed?
Really? Because its like a constant squeak. Not 100%, but it happens once every rotation of the wheels. My truck rides like a brick because the shocks are shot, could that be part of it?A bad wheel bearing doesn't make a squeaking sound... A squeak is more likely to come from some sort of bushing. I'd be checking the sway bar links, shock bushings, spring seats, etc.
