Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Exterior
Exterior
Will tire fit on wheel?
This is a discussion on Will tire fit on wheel? within the Exterior forums, part of the 2nd Gen : 1994 - 2002 category!
I'm going to be getting a 98 1500 3.9L 2WD that currently has LT225/75R16's. One front tire is pretty bad ...
Like Tree1Likes
  • 1 Post By dapepper9
Sponsored By: BAK Factory Outlet
Reply
Old 12-22-2016, 06:13 PM   #1 (permalink)
Ram Year: 1998
Engine: 3.9
Default Will tire fit on wheel?
I'm going to be getting a 98 1500 3.9L 2WD that currently has LT225/75R16's. One front tire is pretty bad (needs an alignment), and i didn't want to drop $500 right away for new tires / alignment before i get a chance to really check out and replace any other suspension components, and possibly have to do another alignment.
A buddy of mine has two almost new 235/70R16's that i can use in the rear, move the rears to the front, and that will give me timeto replace any bad suspension parts.
Does anybody know if these will fit the standard rims? The calculators online say the difference between the tires is very small, resulting in almost no difference on the speedo.
Thanks all.
Sponsored Ad
Register to remove this ad.
jdaleo23 is offline   Reply With Quote
Old 12-22-2016, 09:29 PM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
10mm wider and same height. You won't even notice a difference
jdaleo23 likes this.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 12-23-2016, 01:15 PM   #3 (permalink)
Ram Year: 1998
Engine: 3.9
Default
Alright, awesome. Just wanted to make sure they would fit on the rim before i picked up the tires.
Thanks a lot!
Old 12-23-2016, 01:36 PM   #4 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Default
Yup...no problems with running those sizes at all.
The 225's are just 3/10th of an inch taller & 4/10th of an inch narrower than the 235's. Speedo error is less than 1%.
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline   Reply With Quote
Old 12-28-2016, 10:01 AM   #5 (permalink)
DodgeDrew71's Avatar
Ram Year: 2001
Engine: 3.9
Default
Thanks all.
If I may suggest... if you have a good local Firestone (or other alignment capable shop) and they offer a lifetime alignment and you plan on doing some suspension work i'd spend the money on it.
At Firestone they have a $90 1-time alignment or a lifetime $220 alignment. I have taken it in 4 times now--so it has def been worth the money. (In steps I installed new upper/lower ball joints, lowered the front end w/ springs, replaced steering block, idler arm and pittman arm and new tie rods.)
__________________
-Drew
2001 Ram 1500, 2WD, Std cab, 3.9
2/4 drop from Suspension Specialists
Volant CAI, Magnaflow Exhaust (cat back)
DodgeDrew71 is offline   Reply With Quote
Old 12-28-2016, 10:06 AM   #6 (permalink)
Ram Year: 1998
Engine: 3.9
Default
That's a great idea. I'll check with my local shops to see if they offer anything like that. Thanks!!
Sent from my Nexus 6P using Tapatalk
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wheel and tire help Mdogg1386 Exterior 2 06-25-2015 09:03 PM
tire and wheel help Cowboy345 Exterior 2 05-10-2015 08:04 PM
Wheel and tire help! Unit_91 Exterior 0 05-27-2014 04:15 AM
Wheel and tire Help!!!!!!!! countrylife85 Exterior 6 12-31-2013 02:02 PM
Wheel and tire help!! Rammin2500 Tech Info 7 10-28-2011 09:45 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
