1998 Quad cab drivers seat bottom bad
shortlid
Derry, NH
Magnum 5.2
Ok so wires that hold up drivers side of the bench seat in my 98 Quad cab almost look cut underneath? So taking bench out, re doing wiring. Can a swap seat bottom from drivers side with pass side while I have it out?
S
shortlid
Derry, NH
Magnum 5.2
Spring assembly
It's not the seat bottom., it is the spring base. Pictures attached. Previous owner used rope as temp fix.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
That is the actual seat bottom, its 4 10mm bolts that hold them in place, can swap between pass and driver.
S
shortlid
Derry, NH
Magnum 5.2
Thanks
Great so I can swap pass driver, awsome. Where are the 10mm I have to remove to get seat bottom out?
DodgeTx
SEGUIN
In that first picture you posted you can see 3 of the four, they are in the four corners under the seat. then you simply lift up, some come out easier than others.
