this should list what you're looking for. Ambient temp and airflow past the AC condenser is important.
Doesn't matter what year you have. A good rule of thumb is a 20-30deg temp difference across the evaporator is what you should have. Example, 80 deg inlet air should give you between 50 and 60 output air.
Thanks but I have a 2001.
This is from the 01 manual.
