dash change
jbmobbs
murfreesboro, tennessee
ok well i found out the whole inside of my dash is crumbling idk why but it is (the top is fine) and i was wonderin if a 98 model dash will bolt and plug right up in the truck and if id be able to use the 98 gauges and airbag as well????
the codes
Houston, Tx
Magnum 5.2
I wouldnt know but if you need pics of a 98 guage cluster and where it connects, I can get them cuz I have to take mine back out again in a few days.
jbmobbs
jbmobbs
please do, all i need is the pic by the junction box on the fire wall, i might make the 96 model gauges work in the 98 dash
the codes
Houston, Tx
Magnum 5.2
check out my mod thread and go back a few pages from the last...theres a pic of the back of the cluster, it plugs into two black plugs.
SmokedRam
Zephyrhills, Florida
That would be more trouble than it's worth...if you were going to go to that extent, it would be smarter to get some fiberglass and make a custom dash...It's not like the 98 was any less prone to cracking anyway...
jbmobbs
jbmobbs
i like the style of the 98 dash......is that bad??? i mean i might have to splice some wires but it will be worth it to me lol
SmokedRam
No, not at all...i am just saying the effort it would take to get a 96 cluster to fit into a 98+ dash and get it to properly work just wouldn't be worth it...that's just my opinion.
jbmobbs
jbmobbs
yea true but i might be able to splice wires to get them to work or just buy a COMPLETE wiring harness and swap it from this pull and save up here lol
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I do believe that the pre 98 cluster was an analog cluster. The mileage is the old style and not the digital correct?
txbass06
NE Texas
5.9 Magnum
^^ yup. Our miles still "click" over lol
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
That's what I thought. So there is no way to make the new cluster work as the miles are not stored in the cluster. They communicate with the PCM to get the miles.
jbmobbs
jbmobbs
i know thats why i said, id swap the wiring harness if i can find a whole 1998 + model 5speed truck ill buy it and gut it all from the dash to the wires to the pcm and put it all in mine and transmission
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
So you would be changing your PCM too? along with new harness and dash?
jbmobbs
jbmobbs
yes, my brother is a mechanic at the dodge dealer and he said he would flash the pcm so it would display the correct milage and model of the truck
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well if you are gonna go that far shoot have at it. Let us know how it turns out.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
^^^^Sounds like a good idea. I'm sure there are many guys that would like to do the same.
