dietDrThunder
I have read many hundreds of posts, and am still not clear about something, so I'm asking for some info.
Ok, so I bought a 2001 Ram 1500 yesterday on the cheap, and I like it a lot. I already knew that the top dash panels and gauge bezels fail, and this one is no different...I have replacements on the way.
Now...I need to replace the heater core. I always thought that the dash problems were specific to the two pieces I mentioned above. But, the mechanic is worried that when he removes the dash to do the core, the whole thing could fail catastrophically. Not just the top, but the main dash assembly, such that you couldn't even put the truck back together.
Is this right? I thought it was just the top and gauge panel that failed. Is there really a significant possibility that the whole thing could crumble, leaving me with no dash at all? Does this actually happen? Isn't the main dash assembly made out of steel?
Am I missing something?
I'm going to be super sad if I bought this truck and did a bunch of work to it, only to find out that I can't fix the heat because the cure might be worse than the disease here.
Thanks guys...
Thanks guys...
