emergence brake lever
Richard1998
Bellevue, Iowa
cummins 5.9
Hi new to this forum I have a 1998 RAM 2500, and the emergence brake release lever in the cab broke I can not figure out how to get it out to replace with new one any one know where to get drawing or how to remove it
Thanks Richard
dudeman2009
Magnum 360
Should be pretty simple once you get some slack in the cable. There is a cable tensioner nut under the cab on the driver side where the single cable splits into two. Once you loosen that, you'll likely need to pull the plastic access panel next to the parking brake pedal or even the carpet. Then you should be able to unplug the dash light connector from the pedal and unhook the cable, then just unbolt the pedal.
R
Richard1998
Bellevue, Iowa
cummins 5.9
thanks dudeman, I guess I was not clear about my problem what happened was the plastic release lever 0n the dash has a boss on the back and plastic boss broke , I can't figure out how to get plastic lever of to replace it.
Richard
dudeman2009
Magnum 360
Richard[/QUOnope, thats on me. I had a thought and ran with it.
Reach under the dash to unsnap the plastic retainer clip that secures the park brake release rod to the park brake mechanism on the left side inner panel. Disengage the park brake release rod end from the park brake. Lift the park brake release handle to access and unsnap the plastic retainer clip that secures the park brake release rod to the lever on the back of the park brake release handle. Lower the park brake release handle and reach under the dash to disengage the park brake release rod end from the lever on the back of the park brake release handle. Lift the park brake release handle to access the handle mounting bracket
1Popeye
