Interior lighting
JMikk
5.2L 318
I'm looking to freshen up the interior of my truck, I'm going to put in led some lights and such but I want to make my cluster and vent controls ice blue but I'm not sure how many bulbs I need to do so, anyone else know?
Hot Ducer
Atlanta Ga
Not sure on the 2001, but on my 03 SLT there are 3 in the AC controls and 11 behind the cluster. Also I replaced the greens with white and they came out blue.
2003 1500 QuadCab 5.7 4x4
J
JMikk
5.2L 318
Get a pack of 10 and you'll have extras
Thanks bud, do you happen to know about the ash tray, cup holder and glove box light bulbs? I have no idea what size they are to replace them
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
194 bulb.
Check out superbrightleds.com, not the greatest place to buy little interior bulbs because of price but great way to find out bulb numbers
True. They're high, but way more reliable and brighter
dudeman2009
Magnum 360
I gotta vouch for superbright. I've replaced the dome, cupholder, headlights, fogs, brake, and bed lights. They are all nice and bright (you gotta dink around on their website a bit to find the really bright fogs, otherwise you get some dim bulbs that are more fit for interior lighting than fog lamps.
I've had a couple problems with them, and their warranty service is great. One of the bulbs was DOA, and they got a new one to me in 3 days. The cupholder bulb started failing due to heat (you cant just shove it into the stock bulb holder I found out) and they got the replacement to me in 4 days. Both times at no cost to me. Now i've got to send back one of the voltage converters for my headlights as the diode bridge inside has failed, one of the diodes has shorted (kind of my fault, but they said they'd cover it).
You can only get white or cool white which are about 5K and 6.7K, for headlamps though. You can get a myriad of colors for interior lighting however.
Sure they are more expensive, but i'd bought a 10 pack off Amazon before I found superbright, and I went through 4 bulbs in one month in my dome light and cupholder. Its only a couple dollars per bulb for interior.
