Need help
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yea it will change the color. So maybe. Hell worth a shot right.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Look what I found on another forum, it's a tahoe, but it should be the same concept...
"The only thing that takes a couple of tries to to re-calibrate the needles.
First time I did it wrong and when I filled up with gas it only showed 3/4 full and the speedo was showing 70mph when i was at about 55 mph.
Easiest way to recalibrate is before you put the needles back on you connect the wiring to the gauge WITHOUT turning on the ignition.
Once connected you hear the needles go back to their 0 position.
Then while it's connected push your needles on in the "0" position.
Then disconnect the wiring and turn all the needles to the 12 o clock position.
Then replug in the wiring into the back of the gauge and the needles should all return to the "0" position.
If they are not exact then repeat the process till they return to the "0" position.
Once they are correct then put the plastic cover back on and re-attach the gauge to your dash and put back the 4 screws.
Then put your dash bezel back and your good to go."
AWE Daniel
Banned
Hey Colton you never answered on the other thread about you and mike driving to tampa
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Oh sorry, I'm not sure. Have to play by ear, but we might be able to. I'll let you all know
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Good find Colton. Sounds like a plan on the needles.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Ok... I got the right side gauges to work (speedometer, fuel gauge, and oil pressure) the three on the left (tach., engine temp, and battery voltage) are still off. I think I'll be able to fix the temp and voltage gauges, but the tach seems pretty screwed up... oh well... life lesson learned here, don't screw with things you aren't sure about or don't know much about. I feel ******** :crazy:
ramthis9501
ramthis9501
Oklahoma
5.2 V8
I will, but I'm done with them for tonight. I got the whole week off so maybe I can get them fixed in the next couple days.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Do I still need to do a writeup on this or can I just say... NEVER f*ck with the needles! Ever!!
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Lol ummm yea best advice. Don't mess with the needles noted. Lol
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Haha I'm just gonna put in my white LED's and be happy with what I got. It'll look good enough, don't you think? A really light blue, almost white.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I think that would look good. I personally am a fan of white and blue. So the combo is good.
