Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Interior
Interior
overhead console light issue
This is a discussion on overhead console light issue within the Interior forums, part of the 2nd Gen : 1994 - 2002 category!
well, i have a working overhead console, not broken lights work when manually turned on but when you open the ...
Reply
Old 09-03-2016, 07:24 PM   #1 (permalink)
Ram Year: 2001
Engine: 5.2L 318
Default overhead console light issue
well, i have a working overhead console, not broken lights work when manually turned on but when you open the door or turn on the cabin lights with the light control they dont turn on... what could cause this issue?
Sponsored Ad
Register to remove this ad.
JMikk is offline   Reply With Quote
Old 09-03-2016, 11:41 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
A few things. Does your dome light work?
The yellow wire going to the map lights from the connector is for the door sense. This should read 0 ohms or have continuity to ground when the doors are open. This can be tested with a test light if a multimeter is not available. If there is voltage, then the harness for the lights,switches is bad and either needs repair or replacement. If there is no voltage, but your dome light works, you need to find the connector in the center of the instrument cluster and verify that the wire has continuity from the lights to that connector.
Attached is a picture of the harness and relevant connector location. The connector is a 22 way connector, but we are only interested in 3 of the pins, all yellow wires. Attached is a picture of the connector and the three wires that should all have continuity between them. Pin 12 (the middle of the three outlined pins) goes to the map lights.
If there is no continuity between pin 12 and the yellow wire by the map lamps in the overhead console, then the wire is damaged. If there is continuity, the connector is damaged. The easiest way to repair this problem is to splice the wire coming from pin 12 to the wire coming from pin 11, making sure not to damage the wire as it enter the connector on pin 11.
Old 09-04-2016, 12:33 AM   #3 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
Did you wire up the 2 power sources plus the ground? Take a hard look below....
GoldDot is offline   Reply With Quote
Old 09-04-2016, 03:38 PM   #4 (permalink)
Engine: Magnum 360
Default
Where did you get those pinouts from? A haynes or chilton manual? What year? I'm curious because there are some slight errors in the factory service manual.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Overhead light console rattle 4X4Sport Audio & Electronics 9 04-19-2016 12:25 PM
Ram overhead console Express Man For Sale 11 03-22-2016 09:03 AM
Overhead Console and Center Console Armrest Dantheman For Sale 13 11-19-2015 04:56 PM
Overhead center console light -- can it be turned off? toofart Interior 8 09-04-2013 07:27 AM
Overhead Console M C Interior 3 05-29-2011 12:32 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
