It is definitely a doable project. I have done it in a couple Chevy's, and one nice thing about them is even the ones with stock bench seats, the floors already have the dimples for where to drill to install buckets. And half the time they already have nuts welded in place for the threads. Idk about dodges, but i do know that it is 100% possible, and if you have the full seat, should bolt in, even if you have to drill a couple new holes, they should be easy to find where to drill em. as for the wiring, grab a wire diagram online and start playing with the plug. If you a decent electrician (ie, you know how to do it, but don't do it on a regular basis,) you should be able to figure out how to wire everything up pretty easily. I am by no means an electrician, but i am confident that with enough time i can wire up anything perfectly! i'd say do the swap, but make sure everything works first, as these motors for the seats are known to go out. Mine needs to be rebuilt. thats for sure. lol
