Mm88swrt
- Aug 23, 2017
- 7
- 1
- Oregon
- 98 ram 2500 5.9 gas, 02 ram 2500 24v
- 5.9 gas, 24v cummins
So I just picked up an 02 24v. Had a hard start issue when I picked it up. Replaced the check valve, gaskets on the banjo that are on the back of the head. Checked all fuel line fittings and made sure they were tight. The lift pump has been replaced, not with an airdog or fass, unsure of the brand but its in the factory location. Looks like the original carter pump stlye. I've got 18psi at idle so I know I have fuel pressure. Any thoughts on what this could be? And worst case is there a way to test the injector pump?
