1996 dodge ram 1500 idle problem
JDavus
5.2 magnum v8
I have a 1996 dodge ram 1590 5.2 318 v8. Past few days everytime I go to crank it it would start off in a low idle position n then cut off as if I turned off the truck my self. I had a complete tune up done new fuel injectors n a new fuel pump. New intake gaskets n some other odd things. Plz get back with me ASAP
J
JDavus
5.2 magnum v8
Could it be battery?
Merc225hp
NA
truck
gas
Possible IAC or fuel pump. Fuel psi at the rail should be 49 psi.
J
JDavus
5.2 magnum v8
Iac? I just had the fuel pump put in like 2 months ago
MoparMagic'00
Arkansas
5.2 Magnum
Don't really matter when the pump was installed they often sit on shelfs for a while before sold and can be faulty from the manufacturer. One thing I've found out the hard way is if it is man-made it can have man-made faults..
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Idle Air Control valve, battery, or fuel pressure.
