Greetings,
I have had this problem for a while. I have replace Idle Air Control motor, cleaned throttle body (new gasket). I have had a local shop trouble shoot this problem. They determined it was an intake gasket. Paid them to replace the intake gasket. All seemed well, but its a couple months later, the temp is staying cooler and the problem has raised its ugly head again.
Starts fine, drives fine, but slow down to stop, or slow to turn and the idle will drop below 500 rpm and it will stumble and die. It doesn't always do this but it does it enough to be a pain.
Before I consider taking it to the shop again, I'd like to get some ideas on what the real cause of this problem could be.
thanks in advance.
thanks in advance.
