Dassquatch
- Mar 14, 2012
- 2
- 0
- 1997
- 5.9l magnum
Good Evening Everyone,
So...
I've got a 1997 Ram 1500 4x4 with the 5.9l V8. When I start it, it stalls out immediately. No chugging or anything else, the RPMs just drop off and it doesn't recover. It runs fine, but I've got to work the brake and throttle pedals at the same time. I have replaced the IAC previously. Before, it would be a year or so between failures. This last time was about 2 months before it started doing it again today. After seeing the pattern, my question is:
What is the background issue? What are the other potential causes for the premature failure of the IAC? And the other potential issues that could be related?
I turned the key 3 times and got these codes, in order, as presented:
12: Battery Disconnect
Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections.
25: Idle air control motor circuits
A short is detected in one or more of the idle air motor circuits.
21: O2S Stays at center
O2S shorted to voltage
O2 sensor does not detect rich or lean condition, or O2 sensor input voltage too high. DRB will indicate which side with dual sensors. The O2 sensor signal should fluctuate under normal conditions.
55: N/A
End of message code. A DTC 55 is used to end all DTC messages. This code does not show on the DRB tool and indicates a completion of the stored codes on the Malfunction Indicator Lamp (check engine lamp).
That spawns another question: Why did I get 25 twice? Are there multiple IACs present?
Any help would be greatly appreciated.
V/R,
Jason
So...
55: N/A
V/R,
Jason
