I recently bought a 2000 1500 Sport 4x4 with a 5.9 The truck has 185,000mi on it and the previous owner had put an electrical after market radiator fan system.
We removed that system and installed a new fan, fan clutch, and shroud to get it back to OEM. It all ran fine until the other day when I drove it about 50miles to my destination and when I got there, the engine had just started to get very hot so I shut it off. The radiator fluid was boiling hot so I let it sit. When I went to leave, the engine was cooled again so we drove the same 50 miles or so home with no problems. Ran a couple errands and then drove a few miles home and when I got home, the engine temp was once again starting to climb.
Any suggestions on what could be causing the engine to run fine for a good distance, get hot, cool off, then drive fine again? I'm wondering if it's the thermostat, but would that cause it to over heat faster than 50 miles down the road?
Thanks
Thanks
