RebelRam01
I have a 2000 Dodge Ram v10 which is a total ******* lemon, I hate to say it. The motor has blown already, which was replaced with a low mile motor and the transmission has also went out which was replaced by a Jasper tranny. Ever since I had this truck, new tranny and old, it gets a little funny around 45 mph. It will shift between gears rather hard, hard enough it sounds like the engine can't keep up with it. It is an automatic as well. I've looked online and so much in this truck has been replaced I can't see how anything is still wrong with it. I heard of a term called 'bucking' which seems to me what it is doing. It will throw you in your seat when it shifts from 3rd to 4th. All other gears are fine. Every now and again it won't shift at all, the rpm's will fly up before it decides to go into gear. It will most likely go back to the shop being the transmission is under warranty. I have heard of replacing a type of govenor and a pressure solenoid as well, does anyone have any input?
It's about ready to go into the junkyard.
