Lethalweapon100
Hi everyone. 1997 Ram 2500 5.9 V8. 46re. Today i did fluid and filter, along with a band adjustment. Im confident everything is correct, including band setting and fluid level.
When it goes to shift from 2nd to 3rd, it will only shift under very light throttle or no throttle. Even with light throttle, it will rev right to redline. Just...slowly. Itll shift once you take your foot off of it, and after that, shifts fine. Just 2-3 is sticky for some reason. It kiiiiind of did this before the work, but only under heavy throttle. Now it occurs under anything over very light throttle.
Thoughts?
Sent from my SM-G920P using Tapatalk
Thoughts?
