Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
4.56 Regearing
This is a discussion on 4.56 Regearing within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
I did search and found nothing sorry if I missed the thread. So I'm looking to put 4.56 gears in ...
Sponsored By: Moe's Performance
Reply
Old 01-04-2017, 09:16 PM   #1 (permalink)
Ram Year: 1999
Engine: 5.9l Magnum
Default 4.56 Regearing
So I'm looking to put 4.56 gears in my 4WD 99 ram 1500 with the 5.9l on 35" grabbers in the near future.
Did a little research and I'm leaning toward having a shop do it because I don't feel like buying 200$+ worth of specialized tools. But I want to buy all the parts spaced out so I can afford it. So I'm leaning toward Motive but what do you guys recommend. I know I need a ring and pinion set and an assortment of shims but can someone give me a list of all the parts I need for the front and rear re gearing. Rear is the crystler 9.25 front is Dana 44. Both bone stock. Any insight is greatly appreciated.
Sponsored Ad
Register to remove this ad.
Redneck760 is offline   Reply With Quote
Old 01-04-2017, 11:29 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 360
Default
I'm not telling you to do it yourself, if you don't want to. But some of the tools can be substituted, and the ones that can't have other uses. You can even make your own if you have a small welder and some basic drills and saws.
The hardest part, is doing the work on the ground.
If you feel you can do it, i'd take the extra couple weeks and spend the same amount of money you'd likely be paying in labor, and just do it yourself. Most places charge between $60-80 and hour, you're looking at a minimum 2 hours unless the guy is booking it.
Old 01-05-2017, 12:19 PM   #3 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
Its going to be a lot more than 2 hours.
You need gearsets and install kits. There's minor and master install kits depending if you need bearings, seals, etc. Make sure the front kit is made for our CAD system with the intermediate shaft bearings. For the front dana 44 you will need either thick cut gears or an offset carrier made for 3.92+ gears.
:Try to look for regear packages, you can usually get a good deal on gearsets and install kits. IIRC justdifferentials and eastcoastgearsupply are two that have some for our trucks.
__________________
BBartow is offline   Reply With Quote
Reply
Bookmarks
Tags
4.56, 4.56 gear install, regear
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Regearing granito1 Tech Info 2 07-23-2016 07:05 PM
Regearing '14 3.21 to 3.92 Revo Engine & Performance 97 05-06-2016 01:20 AM
regearing 4th gen 4.7L 05christj Engine & Performance 16 07-31-2015 10:13 PM
Regearing --- help! whitethunder Engine & Performance 12 03-06-2015 02:43 PM
regearing help big_red_ram Engine & Performance 10 05-21-2014 05:59 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
