Bthompson
- Sep 4, 2017
- 17
- 5
- 2001
- 5.2 magnum
This is what I have so far
KB +5cc pistons and ring kit
KB Floating pins with lock rings
Huges FI airgap intake with billet rails
EQ heads (1.92 intake valve)
Stock block, crank, rods, stock lifters, stock pushrods.
The truck is mostly just a weekend toy/ occasional creek bottoms but that’s it.
What I need help with is the top end. I don’t want to run into any problems with valve clearance or anything.
What cam should I use? I still want to be streetable and whoop a few here and there.
And with the cam will Harlem sharp 1.7 rockers be able to be used?
I will be getting all this tuned on the dyno along with 4.10 gears front and rear on 33’s
