Hi guys, First off, im impressed with the site, I'm on a couple other boards for other vehicles, but this one is really well laid out! Kudos!
On to what brought me here....
I have gotten a 1999 Dodge 2500, 5.9 V8, 2WD, that the prev owner couldnt get running and its still being very stubborn and will not run...
I have replaced the Battery, Distributor cap, rotor, sensor under the cap, throttle position sensor, and now the Crank sensor.... and still no dice
I checked fuel pressure at the rail, key on it primes up to 45psi, and under cranking stays roughly around that area but bounces pretty terribly yet doesn't really drop off completely...
I checked spark with an inline light, off the coil i have a distinct pulse to it, and at each plug i have a couple flickers and a pulse repetitively...
I am not throwing any codes, and all seems to be well guage wise.....
While cranking (with petal to the floor) full throttle, it will act like it wants to take off and somewhat fires, but just surges and falls off again.....
I tried dumping some gas down the throttle body, but doesnt seem to really affect anything......
I also verified plug wires are going to their correct spot and are in the correct spot on the cap....
this thing truely has me stumped....
