My '98 2500 just surprised me with a wierd issue. I had just finished hauling an 11000# trailer from a family camping trip with the horses. Ran great. About an hour into unloading, I unhitched the trailer and ran into town for a pizza. About a mile from home, the engine abruptly started misfiring on all cylinders. It idled fine, but wouldn't rev beyond about 1500rpm. I pulled over, shut it down and took a look. Seemed like the engine was mildly over heating (210F normally doesn't go above 200F), and a bit of coolant had leaked out the radiator cap. After 10 min, I started it back up and it ran fine like nothing had happened.
I took it for a test drive the next morning, with similar results (ran fine until suddenly unable to rev nuch past idle)
ECU showed nothing but misfire codes, and showed a slightly elevated engine temp (208F)
After that, it starts fine, idles fine, and seems to rev fine in my driveway. However, the symptoms return within a block after leaving the driveway.
My guess is either a weak ignition coil, or some kind of ECU limp mode from the engine running hot. I'm going to check the ignition coil on my multimeter this evening.
Will multimeter testing detect a flaky ignition coil or just a dead coil? Is there a better way to smoke out a flaky coil?
If the ignition coil checks out as good, what other culprits should I check out?
Are the mildly high engine temps likely related? (Could the ECU be detecting it without logging a fault and putting the engine in limp mode? No temp faults are getting logged in the ECU)
Sent from my SM-G950U using Tapatalk
