Jedeka
- Dec 24, 2015
- 21
- 1
- 1994 and 1997
- 408 and 5.2
This truck has been running fine until a couple days ago, when I used it to plow some snow. What started out as a couple hiccups, has now turned into a hesitation, dying and rich running conditions. Fuel pressure is a steady 45 psi and will maintain the pressure after shutting off the truck. It seems to get worse after the engine starts getting warmed up. No CEL, spark is good as well as cap and rotor. I had my scanner on it and thought MAF sensor was running above the specs. Replacing the MAF sensor did not help. I removed O2 sensor without change. I swapped out IAC with a used one. Now engine will not idle without foot on throttle pedal. This leads me to thinking it is an IAC problem. The other day when it died, I had to try 10 times before engine would stay running. Sometimes when it died, it would start right back up. If it started to die and I gave it some gas, it would hesitate like a bad accelerator pump. Spraying a little either into the name pipe would not cause the RPM to increase. Pulling off the brake booster hose would cause the RPM to increase a little and seemed to run better. At one time I was thinking crank sensor, but now I'm unsure where to look. Thanks.
