96 charging problems
EDDNIE
EDDNIE
LONG ISLAND NY
2009 1500 DEEPWATER BLUE, 1996 INDY RAM, 2019 bighorn
5.7 HEMI, 5.9
96 ram
Thanks for the compliment, I try to keep it clean. 16,900 orig miles
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
Charging issue
Replaced battery temp sensor, still have an issue. Installed optima yellow top battery & led bulbs still have issue but gen light not coming on at idle any more. 30 deg and windy & truck is outside under carport. will continue trying to locate problem hopefully it will warm up A touch. I will keep trying any suggestions members offer to solve issue and thanks to all who have tried to help:favorites13:
crazy_luck
Minnesota
Had a similar issue on my '99 Laramie a few years back. Wouldn't hold a charge at idle, battery would completely die over night. Spent weeks chasing it.
Turned out to be a loose/damaged ground connection on the frame... :Stupid Me:
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
96 charge issue
As soon as I get A break with this weather I will be rechecking all grounds again & again. Thanks:favorites13:
Merc225hp
NA
truck
gas
Yes check all the grounds can't hurt one bit. Ok I know you had the alt checked, fine. It's time to go get a new or rebuilt alt, treat it with care install it run the truck up and see what happens, if no change return it. I am going with the fact you have the Mopar performance pcm in that truck, it puts out more volts (14.5) than the reg pcm does.
Edit; Grrr don't know how I missed it but you have an underdrive pulley on that alt. Put the smaller stock one back on.
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
charge issue
Allready tried another alt, performs exactly same. Tried smaller pulley belt loose & could not find size that fit correctlly, Also, local mechanic said that if it came that way it charged properly when they sold it new ? not agreeing or disagreeing with any suggestions, just want to solve problem.
underdrive pulley 3 3/8" dia with stock belt 7pk2475
stock pulley 2 5/8" dia tried next smaller belt 7pk2476 1" shorter to tight:shake:
Merc225hp
NA
truck
gas
Ok well all the pulley's need to go back to stock size to solve your belt size issue (alt, crank, maybe waterpump). That is an underdrive pulley kit, it did not come stock on that truck someone installed it before you got it. The performance pcm and all these trucks are very sensitive to volts, it won't like that underdrive pulley kit at all. I have seen the same results with others that have used the underdrive kit.
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
96 charge issue
Thanks for the heads up, I dont know where I am am going to get the stock pulleys but I will see what I can come up with. I have the alt pulley, I need the stock water pump & crank pulley's for A 96 5.9 L. The search begins
Merc225hp
NA
truck
gas
Let me know if you need parts I will ship to you asap.
Ok on a side note: I also have the Mopar performance pcm same year same motor, I protect mine at all costs, treat it like gold. No jump starting or boosting, no welding with the batt hooked up, No dealer is allowed to plug into my obd1/2 port ever, no software upgrades ever, No tuners. Our pcm's are part OBD1 & OBD2 the only year for this.
Mopar part # is P5249935 Engine Controller (1996 5.9L ATX Ram). They are not cheap and are getting very hard to find. If you want to use a tuner go find a used stock pcm and install it to use with the tuner, put the performance pcm in a safe spot for later on.
Edit to add.
HUB, PULLEY. Water Pump, Water Pump Pulley 53010221 NLA
5301 0222 crank pulley 3.9/5.2/5.9 Engine NLA
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
96 charge issue
Thank you once again merc, I went on the local dodge dealers website and ordered w/p & crank pulleys. I wanted new I am not going to trust salvage yard parts on my truck, new parts will run straight and true:favorites13:
Merc225hp
NA
truck
gas
Parts pc shows -1 back order for the water pump pulley and the crank pulley shows NLA, hope its wrong.
So far I have found this kit be it a small power/amp kit at least you get all the pulleys needed.
http://www.summitracing.com/int/parts/mch-10515/overview/make/dodge/model/ram-1500
You could put the org alt pulley on and the org belt and oversize either of the two idler/tensioner pulleys or maybe just the one.
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
96 charge
As soon as I receive replacement stock pulleys and check to see if it resolves issue I will post. Thanks everybody again.:waytogo:
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
Pulleys
Received shipping confirmation for 2 stock pulleys, Fingers crossed this will solve charging issue & A shout out to merc225hp, The man is A class act, many thanks again. Will post with results. T/Y:favorites13::peace:
EDDNIE
EDDNIE
LONG ISLAND NY
5.7 HEMI, 5.9
Charge issue
Installed all stock pulleys on truck, charging gr8. Looks like underdrive kit was the culprit. Special thanks to merc225hp for all his help and patience finding problem. GREAT WEBSITE & GREAT MEMBERS !!!!!!!!!!!!!!!!!!!
BY THE WAY FOR SALE: SLIGHTLY USED UNDERDRIVE PULLEY KIT, HAHA:ROFLJest::ROFLJest::ROFLJest::party52:
Merc225hp
NA
truck
gas
Very kool :) nice it worked out for you. Nope don't want it lol and Happy Trucking.
joeyoliver45
