97 5.9 V8 Timing chain and sprocket replacement question
Lethalweapon100
NY
V8 5.9 Magnum
What holds tension on the timing chain on a 1997 5.9 V8? Anything? Is there just no tensioner? That kind of freaks me out, leaves me a bit nervous.
Thanks all
Sent from my SM-G920P using Tapatalk
e_hartzell17
From my experience with my 5.2 which is mostly the same inside, there is no tensioner on the timing chain in is literally just held tight By the distance between the two gears
dapepper9
Iowa/Nebraska Border
5.9L V8
Don't really need one but you can certainly install one. My 360 never had one and i didn't put one in when i swapped to a double roller. I see it as one more thing to wear out on these
