First is to check the alternator to make sure its charging properly. It should be outputting anywhere from 12.8-14.5V at idle. If its below that mark you have a charging system issue. If that checks out good then you have a parasitic draw problem. First is to remove/unplug all accessories, there are a couple ways to check for parasitic draw. The easiest is to get yourself a current shunt, a 50A shunt is enough to allow the key to be put in the run position while also providing enough accuracy with key off to get a good reading for parasitic draw.
Another option is to loosen the top post on the battery so you can pull it off by hand. Take a multimeter with both a 10A range as well as a milliamp range. At first you'll have the positive terminal loose and turn the key on, let everything boot up then shut it down and wait 10 minutes. After 10 minutes take the meter in the 10A range and hold one probe to the battery post and the other on the vehicle connector. Then remove the vehicle connector from the battery post, if it reads less than .1A put the vehicle connector back on the battery post and repeat in the mA range. If its more than .1A you have major draw coming from somewhere. In the mA range you should have less than 30mA draw, anything more indicates a draw of some sort.
