memphismissile
- May 25, 2014
- 8
- 4
- 1999
- 318
OK guys I'll try to keep this as short and accurate as possible... I'm new. 1999 Ram 318 I have this vehicle since new. I've had coolant issues pretty much the life of the truck, poor heat, coolany odors, etc. However, I think we have reached our "boiling point". Recently replaced timing cover due to small gasket leak. Drove truck a couple times, no problems. This weekend I pulled the camper (not the first time) and the nighmare began. The truck overheated a few miles into the trip but the guage never told me that. Extreme boil over. Cooled her down, added a little water and drove it on to the camp, only a few miles.
Once at the camp we noticed it would heat up everytime I drove it but didnt heat up just at idle. Removed upper radiator hose and just a trickle of flow. So, removed the thermostat. The t stat was stuck cause we put it ina can of boiling water, never opened. Buttuned her back up and sure enough, same result...
So there we are in a state park, and borrowed enough tools to pull water pump. The pump appears to be good. ended up having the truck towed home.
So, heres my dilema... no matter what I do, short of replacing the water pump, can I get a good flow throught his thing. Radiator is new. Hoses are good,e tc
My fear is i overheated it with the stuck t stat and blew a head gasket. Could be but I have no water in oil or vise versa, and no steam from exhaust.
End of the day it just continues to puke the water out the radiator.
Are we thinking head gasket, or even worse?
btw- the gauge continues to read 130-150 but when i stop and itas boiling, then the gauge jumps up... wth?
