PlowHouse
- Aug 8, 2016
- 4
- 0
- 1999
- Laramie 5.2L V8
[SOLVED] 99 Dodge RAM popping sound at idle
Hey Everyone,
Having this popping sound occur on my truck at idle that's driving me crazy because I can't figure out how to troubleshoot the issue. I just replaced the plenum plate with an aftermarket "Hughes" plate to resolve a common issue found on these trucks with oil leaking into the intake manifold up to the throttle body. While I had everything apart I figured I'd do a tune up as it was easy to access the distributor cap/rotor. So I replaced all the wires, plugs, the distributor cap and the rotor. I decided not to replace the ignition coil as that looks to be working fine but I'm not opposed to replacing it if there's some evidence to support that this popping issue is coming from that. Since doing all this work I've now developed this popping sound that occurs at idle and even while revving the engine although it's not as frequent as it is at idle. I should also mention that I used NGK double platinum plugs for this tune up and insured they were set to the correct gap before installing them. However, the service manual for this truck calls for champion plugs but they weren't in stock during my trip to the auto parts store so NGK it was.
I want to say the popping sound is more pronounced on the passenger side of the engine but it's still hard to tell if it's coming from the plugs, the distributor cap, or even the front pipe. I'll include vimeo or youtube links of what I'm experiencing and hopefully someone can guide me on what I should check to eliminate what could be causing this problem. I should also mention that I re-checked all the boots to make sure they're snapped into the plug as well as the other end on the distributor cap. You may notice from the video that there are different colored wires as well. The mixture in wires is due to a red set of cables that were cheaply made. A few of the boots would not set on the plugs and the metal insert inside the boot would go further up the wire. So when I asked for another set to remove the bad wires I ended up getting black cables. I thought of just doing all the wires and making them the black cables but I wasn't sure if that would matter.
Any help I can get on what I should check to diagnose this weird problem will be greatly appreciated. I don't believe this is a muffler issue as it just appeared to start occurring after I did the tune up but anything is possible. Thanks in advance for reading this and hopefully helping me out.
Video Links below:
vimeo.com/177951051 - part 1
vimeo.com/177951180 - part 2
Hey Everyone,
Video Links below:
