Marksman
- Nov 14, 2014
- 78
- 10
- Texas
- 1999 Ram 2500 4x4 SLT
- V10
Hey everyone. Ever since selling my 84 w150, I've been in the market for a V10 truck in good shape that was cheap, and the opportunity finally presented itself.
The truck needs the usual things, i.e. a dash cap, and some minor upholstery work. The truck was sold because the engine developed miss that is obviously compression related. I'm not sure of the circumstances leading up to the problem, so I'm trying to figure that out. Along with the dead miss, it smokes quite a bit--oil smoke.
I'm prepared to go through the engine, hopefully just doing a re-ring and bearing job. I'm just looking for advice on what you all think might be the culprit with the miss. I have read that the heads are notorious for cracking, but I don't know if a cracked head would cause a dead miss. It could also be a head gasket, or a burnt valve i suppose. As for the oil smoke, the truck has right at 200k on it. Would you suspect rings or valves? It only smokes under a load, which pretty much eliminates valve seals. The engine has around 80 PSI of oil pressure idling cold (haven't run it long enough to get it hot) so the bottom end appears to be pretty tight.
Sorry for the long post! I appreciate any input!
