Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Advice, please
This is a discussion on Advice, please within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
We have a 1999 dodge ram 1500 5.9L V8. My husband recently had his engine remanufactured. He got the engine ...
Like Tree1Likes
Sponsored By: Moe's Performance
Reply
Old 01-01-2017, 06:55 AM   #1 (permalink)
Ram Year: 1999
Engine: 5.9L
Default Advice, please
We have a 1999 dodge ram 1500 5.9L V8. My husband recently had his engine remanufactured. He got the engine back into the truck and started it, but it would not idle. It died as soon as he took his foot off of the gas. The truck was running maybe two minutes total
When he checked the oil, he found a thick, milky substance on the dipstick. I have always been told that indicated blown head gaskets. Is there anything else it could indicate? How can he have blown head gaskets when he just paid $2100 to have the engine remanufactured?
Sponsored Ad
Register to remove this ad.
Truemagnum15 is offline   Reply With Quote
Old 01-01-2017, 09:32 AM   #2 (permalink)
Markcuda's Avatar
Ram Year: 2015-Laramie-1500-CC-4X4
Engine: 5.7
Default
Drain the oil and see what is looks like.
__________________
2015 Ram 1500 Laramie,4x4,CC,short bed,5.7 Hemi,3.21 LSD,Cooper Discover AT3 275/60/20s,Flame Red,Canyon Brown/Light Frost Beige,A.R.E LSXseries fiberglass lid Weathertech front floor liners,McGard premium lug nuts,drop in K&N air filter,Westin tailgate liner,32 gallon fuel tank,spray in bed liner,Dee Zee bed mat,Husky mud flaps,sunroof,2 Swing Case boxes,resonators gone.
Markcuda is offline   Reply With Quote
Old 01-01-2017, 11:51 AM   #3 (permalink)
Ram Year: 1999
Engine: 318 5.2l
Default
Moisture in your oil I have seen that before and wasn't a blown head gasket. Like Markcuda said drain your oil and see what it looks like
Joe w. is offline   Reply With Quote
Old 01-01-2017, 02:07 PM   #4 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
Thank you Any ideas why it will not idle? It starts just fine and runs as long as he does not let off the gas
Old 01-01-2017, 02:30 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Download the factory service manual here in the tech section. Have him read through the distributor procedures, particularly the part about fuel sync and alignment. Highly possible that's not set. If the rotor is in cyl 1 at the right time (you'll understand after reading) then don't screw with it.
After that I'd look at tb sensors
gofishn likes this.
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 01-02-2017, 12:29 AM   #6 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
We did download the manual some time back. He did say he was glad he had the distributor in right because it is a bitch to try to do anything with it once it is back in the truck as it is underneath the dash part so close to the firewall. I will tell him to check the tb sensors. Thank you. Everyone has been a tremendous help these past few weeks. My husband was a papermaker for over 31 years and the so called friend that was helping him with his engine decided not to come back when it was time to install it. It has taken since December 13th, but we can finally see the light at the end of the tunnel. Thanks again all who have responded to my posts. It is truly appreciated. I wish you all a very happy New Year.
Old 01-02-2017, 12:35 AM   #7 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
My husband would like to know what a tb sensor is, please
Old 01-02-2017, 01:40 AM   #8 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Sorry about that, i have a bad habit of abbreviating things that are commonly mentioned while forgetting not everybody is as familiar with stuff.
Tb is the throttle body. Hesitant/rough idle like you described is often caused by the Idle Air Control motor (iac) or the Throttle Position Sensor (tps). Iac controls air going into the engine at idle by using am electric motor to gauge the amount of air that needs to go in. Tps does exactly as it sounds, senses throttle position. Pcm (computer) uses this information in determining fuel and timing. Sometimes the iac doesn't quite open enough or the tps detects throttle input when there is none.
Iac will be on the back of the throttle body and tps will be on the driverside. Personally I'd probably start with the iac because if it's dying after he takes his foot off the pedal, it sounds like the tps is doing its job but when the iac is supposed to take over, it's not.
__________________
Old 01-02-2017, 11:24 PM   #9 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
Thank you
Old 01-02-2017, 11:40 PM   #10 (permalink)
Ram Year: 1999
Engine: 5.9L
Default
Is there a way to check the iac?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need some advice Jsburris Interior 2 12-30-2015 07:12 PM
Next mod advice HemiPower36 General Discussions 25 01-18-2015 07:42 PM
Need advice txtrucker75 Engine & Performance 11 12-09-2014 10:01 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
