Air Intake
ram15
Mendocino, Ca
its a work in progress but here you go im building an intake off the stock one. i just got a 4 inch rubber coupler and a 90 DEGREE pvc elbow now i need to angle it down toward the grille area and it should be good.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
lookin good. just make sure it isnt gonna suck up water.
Mopar1973Man
New Meadows, Idaho
Hmmm... With all the cold air intakes floating around... It might be a good idea to use a live data tool to find out if all your hard work is going to net you any kind of change.
Because technically the stock tube is routed from the passenger fender and should be pulling cold air from there.
Not to knock your idea but to see about getting some sort of change for the amount of modifing that needing to be done...
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Go big or go home.
I have no water problems with mine. Going on a couple years with it now.
quietpeen
2021 TRX
Hellcat
nice, keep us posted. I'm thinking that even if it doesn't net any real gains, it will sound better.
