Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
broken bolt on intake manifold! help me!
This is a discussion on broken bolt on intake manifold! help me! within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Guys i dont know how to go at this but my engine has been exposed to salt on roads and ...
Like Tree4Likes
Sponsored By: Moe's Performance
Reply
Old 01-04-2017, 05:37 PM   #1 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default broken bolt on intake manifold! help me!
Guys i dont know how to go at this but my engine has been exposed to salt on roads and the top of bolt broke on intake what are my options?
Sponsored Ad
Register to remove this ad.
Seanram is offline   Reply With Quote
Old 01-04-2017, 05:44 PM   #2 (permalink)
Bigdaddycodes's Avatar
Ram Year: 2013
Engine: Hemi 5.7
Default
like the actual intake manifold? if so you could try and use a reverse drill bit or an easy out.. but I would recommend just taking the time to take the full intake off and then try to use vicegrips on the broken bolt or if you have access to a welder, just weld a nut to the top of the broken bolt and undo
R.L.K. likes this.
__________________
2013 Ram 1500 crew cab sport 4x4, 2/4 Mcgaughys deluxe drop kit, ported edelbrock supercharged at 12psi, comp 274 cam, custom exhaust, afe intake, hand ported and polished throttle body, HD swap, fast enough to get in trouble and slow enough to want more
Bigdaddycodes is offline   Reply With Quote
Old 01-04-2017, 05:46 PM   #3 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default
i broke the first bolt off on intake and havent messed with any other bolts. the intake is still on my truck.
supertech276 likes this.
Old 01-04-2017, 10:24 PM   #4 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
If you are doing the plenum, just keep taking the rest off. The broken bolt means its rusted in pretty tough so you may need a flat head to GENTLY pry the intake up, just to break the seal. Also, douse the bolt in WD-40or PB blaster while you are taking the rest off.
Once you get the intake off, get yourself a propane torch or something hotter, and some WD-40 (no need to waste the good stuff on this part). Take the torch and heat the bolt up for 20-30 second, the douse it with WD-40 until it stops smoking. If it lights on fire, just let it burn out and don't heat it as much next time. Repeat this once more. Take a pair of vise grips and latch them on TIGHT. Just rock the vise grips back and forth a little at a time, if it moves, just keep turning it more and more on each pass. If it won't budge, go back to heating and cooling 3 or so times. Eventually it will come out.
If you do decide to weld a nut on, its imperative that you do two things. Disconnect the battery, and put the negative clamp on the HEAD, not the block or anything else. Putting the clamp in the intake ports is fine. If you clamp it to the block, current will flow partially through the headgasket, ground straps, and possibly bearings on the crank, con rod, and piston rings/piston.
I broke one bolt on mine and got it out real easy using the heat and cool method.
I'd also take a can of compressed air and blow all the crud out of the bolt holes too. You can also dab your finger in oil and touch the threads on the bolts when re-installing to make your life easier. Just remember, a torque wrench is only accurate when moving, if you stop, it will indicate a higher torque until the bolt starts moving again.
As long as you don't go all 300lb gorilla, you will be fine. Just use a couple touches of oil or assembly lube to hold the gaskets in place and double check everything once you set the intake back down, and you'll be fine.
Rado likes this.
Old 01-05-2017, 11:42 PM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Remove intake and follow the above advice from dudeman. Only thing i would add is cover the lifter valley and intake ports to protect from splatter.
Easy outs are a no no on these bolts. They break every damn time and make the job much worse.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-06-2017, 11:34 AM   #6 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
+1 (or -1 I guess) on the EZ Outs. My dad tried one on of the two bolts that broke on mine and it snapped almost immediately.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
American Racing Nitro, K&N open element, modified 50mm, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, tuned by Flyin' Ryan, Hughes plenum repair, steering stabilizer, 4x4 Posi-Lok
Yeret is offline   Reply With Quote
Old 01-06-2017, 03:02 PM   #7 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default
Guys check these pictures out and tell me that pletnum is shot. i am also going to try to heat the bolts up tomarrow.
OnSale likes this.
Old 01-06-2017, 05:41 PM   #8 (permalink)
Engine: Magnum 360
Default
That crud is pretty common on the bottom if there has been intervals with way to much mileage on the oil.
The only way to tell if the plenum was infact bad is to unbolt that plate on the bottom and inspect the gasket.
You have plenty of height left on that bolt to get it out no problem. Just take it slow, nothing is done better because you shaved 5 minutes off.
Old 01-06-2017, 06:06 PM   #9 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default
The gasket failed, I saw where was was no gasket and it was brittle and took 30 mins to to scrape it but I might have to take head off. Cause one bolt is flush with the exhaust gasket and no nub I can grab with my finger. What about drill and tap?
Old 01-06-2017, 06:09 PM   #10 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default
Also would it be bad if I used the old steel plenum pan? It doesn't seem warped or nothing just the gasket failed.
Reply
Bookmarks
Tags
broken bolt advice, intake manifold
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MDS / Engine Ticking = Broken Exhaust Manifold Bolt Space Monkey Engine & Performance 53 12-31-2015 02:30 AM
Intake Manifold Ignition Coil Broken Bolt Help Needed crwnsvn Engine & Performance 3 08-04-2015 04:38 PM
Broken intake manifold bolt causing coolant leak Mr. Baseball General Discussion 39 08-22-2013 01:05 PM
exhaust manifold broken bolt !...any "tricks" ? cj5orion Engine & Performance 4 04-28-2013 07:32 PM
Intake sensors and broken bolt ks2007 Tech Info 7 11-20-2011 10:57 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
