Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
broken bolt on intake manifold! help me!
This is a discussion on broken bolt on intake manifold! help me! within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Ebay aluminum plenum is $72 on ebay from 289guy. I would spend the money and get the good felpro gasket. ...
Like Tree4Likes
Sponsored By: Moe's Performance
Reply
Old 01-06-2017, 06:46 PM   #11 (permalink)
pajeepman's Avatar
Ram Year: 2003
Engine: 5.9 magnum
Default
Ebay aluminum plenum is $72 on ebay from 289guy. I would spend the money and get the good felpro gasket. Wanna go through that again? My opinion. Just the good gasket probably would be fine but........
Sent from my SM-J320P using Tapatalk
Sponsored Ad
Register to remove this ad.
pajeepman is offline   Reply With Quote
Old 01-06-2017, 09:49 PM   #12 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Exhaust gasket? you mean intake gasket?
Well, you are in for some trouble then. The heads are known to crack, usually between valves. Taking it off might make any small cracks worse.
I have had good luck with slightly larger bolts than these by getting a nice carbide drill bit and putting a small hole about half the diameter of the bolt in the middle. Then get yourself a left-handed tap and bolt, then just tap and thread that bolt in.
Forget any device that claims to get stuck bolts out, they are all garbage and a waste of money.
If you decide to take the heads off, you might as well clean and inspect them with fluorescent dye. If they are cracked, they are just going to get worse once you put them back on. Its a decision you have to make.
However, if you want to replace the heads with something nicer not too long down the line, i'd recommend just fixing the plenum and letting the heads and that one bolt stay. It wont cause any damage if you plan on replacing the heads 6-8 months down the line.
Old 01-08-2017, 03:34 PM   #13 (permalink)
Ram Year: 2001
Engine: 5.9 magnum
Default
Originally Posted by Seanram View Post
Also would it be bad if I used the old steel plenum pan? It doesn't seem warped or nothing just the gasket failed.
That depends on who you talk too, lol. I've heard that the problem is the steel pan mated to an aluminum manifold, and i've also heard that the bolts are slightly too long and bottom out. I purchased the ebay aluminum plate that came with bolts and gasket. If you decide you are going to go back in later for heads, you could re-use the oem plate, and grind down the tips on the bolts.
__________________
2001 Dodge Ram Sport RCSB 4x4 5.9 3.55gr
MODS: bbk tb, bosch 24# 4hole inj., hs1.7rrs, 3842superchips, cloyes dbl roller, blackmagic elec fan, volant/spectre cai, 3"hiflo cat, 3"magnaflow, accell coil, taylor 8.2 wires, borgeson steering gear&shaft, rs steeringbushing, modded kegger
mda8569 is offline   Reply With Quote
Old 01-08-2017, 06:49 PM   #14 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Flex measured across the length of the whole pan has shown to average about 0.00015" across. However, many cases have come around of pan bolts being loose upon removal and occasionally missing. Also, factory gasket was shit. Mopar even came out with an updated gasket with a steel core. Steel pan isn't the problem and I've had many guys reuse the pan, take 2 threads off the bolts as a pre-caution, loctite, updated gasket and none have come back saying it blew again.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 01-11-2017, 08:22 AM   #15 (permalink)
Ram Year: 1997
Engine: 5.2 magnum
Default
I just want to thank you I followed everything u told me and I was able to get all bolts out yesterday thanks!!!!!
Seanram is offline   Reply With Quote
Reply
Tags
broken bolt advice, intake manifold
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MDS / Engine Ticking = Broken Exhaust Manifold Bolt Space Monkey Engine & Performance 53 12-31-2015 02:30 AM
Intake Manifold Ignition Coil Broken Bolt Help Needed crwnsvn Engine & Performance 3 08-04-2015 04:38 PM
Broken intake manifold bolt causing coolant leak Mr. Baseball General Discussion 39 08-22-2013 01:05 PM
exhaust manifold broken bolt !...any "tricks" ? cj5orion Engine & Performance 4 04-28-2013 07:32 PM
Intake sensors and broken bolt ks2007 Tech Info 7 11-20-2011 10:57 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
